Frequency control
A project log for Alternate Firmware for FG-100 DDS Function Gen
Reverse engineer the FG-100 pinout and develop alternate firmware that improves some of the shortcomings of the default firmware.
Tim SavageTim Savage 10/20/2015 at 14:150 Comments
Just got frequency control code to work. Is based on the work of Joonas Pihlajamaa in this article which in tern is based Jesper Hansen's work. However I have made some changes to the control loop to use a 24bit step while still using SRAM. This provides much more accuracy at low frequencies, the 16bit implementation spikes up to around +-18% error vs 24bit which reduces this to a peak of +-0.013%*
* See this spreedsheet for the modelling I used to come up with the error values.
Set to 123456Hz ;)
Latest code has been pushed toGitHub. Onto UI...
