Pinout
A project log for Alternate Firmware for FG-100 DDS Function Gen
Reverse engineer the FG-100 pinout and develop alternate firmware that improves some of the shortcomings of the default firmware.
tim-savageTim Savage 10/08/2015 at 14:241 Comment
Between the datasheet and probing with a continuity indicator pinout is quickly found.
There are a few pins free that could be used for other things. Maybe 27/28 could have a rotary encoder added.
Tim Savage wrote 02/06/2017 at 00:59 point
I think pin 23 is actually used to measure the input voltage for a "low battery" notification. My firmware does not have this feature built in.
