Enclosure design
A project log for Micro progmeter
Volt- and ohmmeter plus calculator on 25x25mm PCB
jaromirsukubajaromir.sukuba 12/16/2015 at 10:260 Comments
While firmware is taking the final shape, hardware is still nothing but barebone PCB.
I started my favorite mechanical CAD Freecad and designed rough PCB model
and used it to design enclosure
exported into slic3r
printed via pronterface
and my old crappy printer
and here is "not that great" result
Trying to fit the PCB inside:
Almost there. Hole for joystick a bit off, LCD windows is way too big, printing brim is not completely removed, but I'm on a good track. Oh yes, this time I'm designing the enclosure for threaded inserts for metric bolts instead of using self-drilling screws
I'm working on a enclosure design update. New firmware, as well as mechanical design files are being uploaded to github repository.
