I want to create a few breakout boards for easier connecting between the 40-pin cable and a breadboard project. My idea is to make a small board with a 40-pin boxed header (where the 40-pin flatcable plugs in) that is connected to two 20-pins female headers. The 20-pin headers can be used to connect wires to the project.
I can make multiple of these and use them for many projects, when i want to work on a different project i can just switch the 40-pin flatcable with another one.
More on this later!
