mistakes...
A project log for IW blower 4 - 3d printing test
another ion wind loudspeaker in development
deepsoicDeepSOIC 10/12/2015 at 21:140 Comments
model design went through two iterations already. First one was printed, fails noted, design modified and changed parts reprinted.
The problems were:
* mating system between basket and backplate was not working (too weak, and wasn't fitting, so I broke it attempting to put them together)
* rib on the frame was too small. If I put the mesh in between, the ribs won't cover the basket.
See that ring of plastic that detached off the basket? FAIL.
