Power unit
A project log for A-Hen-Ho
Automation of the hen house. Light, door, temperature tracking. Using Raspberry PI as main unit and Wi-Fi as connection-configuration link.
vikpublicvik.public 10/28/2015 at 20:100 Comments
DIssapointment of the day: the power source requires not a button, but a switcher with a fixation to be switched on. The idea to use the same button to switch device on and then power linux off dissapeared. I definitely want the button, which will make a signal to the linux to shutdown.
