Relay shield
A project log for A-Hen-Ho
Automation of the hen house. Light, door, temperature tracking. Using Raspberry PI as main unit and Wi-Fi as connection-configuration link.
vikpublicvik.public 11/01/2015 at 19:130 Comments
for everyone, who is interested in the relay shields sold by aliexpress. This is schematics of the one channel. Normally Vcc and JD-Vcc are shortened by a jumper. but it's obvious, that Vcc should be 3.3v for raspberry PI and most of the microcontrollers supplied by 3.3V. And JD-Vcc is a voltage of the relay operation and probably should be at least 5V for proper function. Be careful. Raspberry PI don't allow 5V on it's GPIO!
