Happy Halloween 2015
Playing with cheap OLED from China
Parts from China arrived yesterday and decided to make something Halloween related. Nothing spectacular, just having fun.
Thanks to AdaFruit for their libraries. However, my clone OLED does not have a Reset pin, so I had to improvise...
I powered the OLED from Arduino pin D2, allowing me to turn it on just before the library start sending I2C commands. Without this reset/power control, all I ever saw on the OLED were random dots. :-(
Thanks to Nick Gammon for his I2C Scanner. That sketch told me that my OLED I2C address is 0x3C and not 0x78 indicated on the board.
  • Arduino Sketch
    Hari Wiguna10/17/2015 at 19:09 0 comments
    // Happy Halloween
    // by Hari Wiguna 2015
    // 01 - modify to work with Chinese knockoff
    // 02 - Draw Happy Halloween & Pumpkin Face
    // Wiring:
    // Arduino A4 --> OLED SDA
    // Arduino A5 --> OLED SCL
    // Arduino D2 --> OLED VCC
    // Arduino Gnd--> OLED Gnd
    // Potentiometers are on Gnd and +5V, wipers go to A0, A2, A2
    This is an example for our Monochrome OLEDs based on SSD1306 drivers
      Pick one up today in the adafruit shop!
      ------> http://www.adafruit.com/category/63_98
    This example is for a 128x64 size display using I2C to communicate
    3 pins are required to interface (2 I2C and one reset)
    Adafruit invests time and resources providing this open source code,
    please support Adafruit and open-source hardware by purchasing
    products from Adafruit!
    Written by Limor Fried/Ladyada  for Adafruit Industries.
    BSD license, check license.txt for more information
    All text above, and the splash screen must be included in any redistribution
    #include <SPI.h>
    #include <Wire.h>
    #include <Adafruit_GFX.h>
    #include <Adafruit_SSD1306.h>
    #define OLED_RESET 4
    Adafruit_SSD1306 display(OLED_RESET);
    int prevEyeSize = -1;
    int prevEyeRotation = 0;
    int prevMouthWidth = -1;
    int eyeSep = 2;
    int headR = 50;
    #define LOGO16_GLCD_HEIGHT 16
    #define LOGO16_GLCD_WIDTH  16
    static const unsigned char PROGMEM logo16_glcd_bmp[] =
    { B00000000, B11000000,
      B00000001, B11000000,
      B00000011, B11100000,
      B11110011, B11100000,
      B11111110, B11111000,
      B01111110, B11111111,
      B00110011, B10011111,
      B00011111, B11111100,
      B00001101, B01110000,
      B00011011, B10100000,
      B00111111, B11100000,
      B00111111, B11110000,
      B01111100, B11110000,
      B01110000, B01110000,
      B00000000, B00110000
    #if (SSD1306_LCDHEIGHT != 64)
    #error("Height incorrect, please fix Adafruit_SSD1306.h!");
    #endif
    void setup()   {
      // This is a hack to get my Chinese OLED to work.
      // I power the OLED using D2 because my OLED does not have a reset pin.
      // Without this hack, my oled displays static random dots.
      pinMode(2, OUTPUT);
      digitalWrite(2, LOW);
      delay(100);
      digitalWrite(2, HIGH);
      // by default, we'll generate the high voltage from the 3.3v line internally! (neat!)
      display.begin(SSD1306_SWITCHCAPVCC, 0x3C);  // initialize with the I2C addr 0x3D (for the 128x64)
      display.clearDisplay();
    void loop() {
      int eyeSize = map(analogRead(A0), 0, 1023, 0, display.height() / 2);
      int eyeRotation = map(analogRead(A1), 0, 1023, 0, 360);
      int mouthWidth = map(analogRead(A2), 0, 1023, 0, display.width() / 2);
      if (eyeSize != prevEyeSize || eyeRotation != prevEyeRotation || mouthWidth != prevMouthWidth)
        display.setTextColor(WHITE);
        display.setCursor(8, 0);
        display.setTextSize(2);
        display.println("Halloween!");
        //-- Head --
        display.drawCircle(display.width() / 2, display.height() / 2, headR, WHITE);
        //-- Left Eye --
        DrawEye(display.width() / 2 - prevEyeSize - eyeSep, display.height() / 2, prevEyeSize, prevEyeRotation, BLACK);
        DrawEye(display.width() / 2 - eyeSize - eyeSep, display.height() / 2, eyeSize, eyeRotation, WHITE);
        //-- Right Eye --
        DrawEye(display.width() / 2 + prevEyeSize + eyeSep, display.height() / 2, prevEyeSize, prevEyeRotation, BLACK);
        DrawEye(display.width() / 2 + eyeSize + eyeSep, display.height() / 2, eyeSize, eyeRotation, WHITE);
        //-- Mouth --
        DrawMouth(prevMouthWidth, BLACK);
        DrawMouth(mouthWidth, WHITE);
        display.display();
        prevEyeSize = eyeSize;
        prevEyeRotation = eyeRotation;
        prevMouthWidth = mouthWidth;
    void DrawEye(int x0, int y0, int r, int rotation, int color)
      //    display.drawCircle(display.width() / 2 - r, display.height() / 2, r, WHITE);
      //    display.drawCircle(display.width() / 2 + r, display.height() / 2, r, WHITE);
      int x[3], y[3];
      for (int i = 0; i < 3; i++)
        float angle = (rotation * 2 * PI / 360) + i * 2 * PI / 3;
        x[i] = x0 + sin(angle) * r;
        y[i] = y0 + cos(angle) * r;
View project log
