An Uneventful Day
A project log for Variable voltage portable power supply
Variable voltage portable power supply, 2-32V
legionlabsLegionlabs 10/18/2015 at 14:530 Comments
I have electricity, nothing is on fire, nearby politics are stable, and nothing nearby has exploded recently.
Each of these things has been not true for me at various points, so I took advantage of this quiet period to expand the utility of the LiPo RC battery I always keep charged as an emergency power source by building this variable output power supply.
Beyond it's utility as a tool, 24 watt-hours is a lot more than nothing when the power cuts, and I can connect most power sources to it including small solar arrays, and most types of battery.
I hope it is not as useful to you as it is to me!
