Barrel Shifter (2)
A project log for Discrete YASEP
a 16-bits YASEP computer (mostly) made of DIP/SOIC chips like in the 70s and 80s... with 2010's twists!
yann-guidon-ygdesYann Guidon / YGDES 11/24/2015 at 10:580 Comments
The precedent log had a few flaws that I will correct here ;-)
The main flaw was to try to design the logic "in my head" so here is the detailed "equation" for one level of shift, considering an hypothetical 4-bits input, with bits named A, B, C and D (it would still work with only A, B and C but I'm feeling generous).
InputsDCBA
SHL 1CBA0
ROL 1CBAD
SHR 10DCB
SAR 1DDCB
ROR 1ADCB
From there, the circuit is straight-forward to draw:
Repeat and expand: 16 bits instead of 4 in length, and 4 layers instead of just one.
The adjustment logic on both sides will grow in depth, from 1 bit in layer 0, to 2 bits in layer 1, 4 bits in layer 2 and 8 bits (one half on each side) for the last layer. This is where we see the advantage of the integrated AND gate included in each '153 as it adds no overhead :-)
Some overhead is in the decoding and control logic, that is not completely represented here. The /Right/Left signal would ideally be directly coming from the instruction word, if it was better organised, so here is a new attempt:
The instruction bits are allocated in the SHL group:
The opcode can easily be decoded with a simple 74HC138 or '238, depending on the needed signal polarity, and (N)AND gates do the rest in the circuit.
The codes are thus derived:
In the case of BSWAP, the SI4 operand MUST be 0 and the decoding logic will do the swap at the last layer.
I think I like this design :-)
