Smoke 'Detector'
A simple smoke detector using and Arduino and a Carbon Monoxide Sensor.
A simple smoke detector using and Arduino and a Carbon Monoxide (CO) Sensor. How it works: Sensor reads CO levels in the air and outputs them on an LCD. The sensor is one of the MQ series gas sensors. Check out the demo here. https://www.youtube.com/watch?v=KmAjsnwURak
Check out the step by step tutorial here
http://www.instructables.com/id/Smoke-Detector/
  • 1 × Arduino I was using an Arduino Uno
  • 1 × MQ-7 Carbon Monoxide Sensor
  • 1 × Breadboard Electronic Components / Misc. Electronic Components
  • 1 × 10K Resistor
  • 1 × 220 Resistor
View all 10 components
  • 1
    Step 1
    Step-by-step build instructions are on Instructables.com
View all instructions
Will wrote 04/15/2014 at 13:06 point
Nice work... I need one like this at home that won't go off when we cook toast :) Also thanks for the heads up on the Voltaic solar charger, looks interesting.
Dar-El wrote 04/15/2014 at 13:28 point
Thank you!
