Phonesnapper #2
a very simple second version that works great
This version i made after the first one in my projectlist, its really just to simple but works super perfect. All it took was a double suction cup (aprox 50ct) and two little pieces of plastic that I attached to it. simply stich the cup to the back of your phone. and then stick your phone to any smooth surface on your dashboard. its just a matter of first time practice how to attach the cup to your phone, but if you want to remove it from the dashboard you simply touch the little plastic particle of the back cup and the phone with the cup will release simply from your dashboard.
Jasmine Brackett wrote 04/22/2014 at 04:29 point
Definitely a nice simple hack. I'm going to give it a try.
