Cartridge carriage optical sensor
A project log for Canon all-in-one inkjet emulator
Arduino based all-in-one inkjet emulator for those that want just to use the scanner when the printer part failed
BenasBenas 11/01/2015 at 14:510 Comments
After some probing around the flex cables going to the cartridge carriage it was clear which of the pins are for the optical sensor.
Pins 15+16 on the bottom flex (look at the photo of the main board) are the optical sensor pins.
Output is the quadrature signal with the frequency of ~750Hz.
The end of the encoder strip seems to be sensed as the end of one the quadrature signals, with the next one ending ~10 cycles later.
