Programming difficulties
A project log for USB Power Meter
A Powermeter for USB Devices / Gadgets
daniel-griehaberDaniel GrieƟhaber 12/22/2015 at 19:540 Comments
I received the boards 1 week ago and started programming the firmware today. For the 7 segment version of the meter I used a standard 0.1" header for the ICSP but since the OLED version is smaller, i used 0.05" SMD pads instead.
Originally I wanted to use Pogo Pins and build a small programming adapter that you could attach to the back that presses the spring loaded pins on to the pads. But since it took a bit longer for the boards to arrive I now simply soldered the wires directly to the board: -> cheap and hacky but works like a charm :)
the unpopulated boards with the programming header on the back
soldered wires to the programming header
As I said it works quite well but after some programming I lost the reset pad because I did not tack the cables down. This was not a problem since I could still attach the reset line to the pullup resistor but as I said this is a hacky solution.
In the end I also lost part of the the 5V pad. Again, I can reattach the cable o another component so the board still works fine.
