Can It Mill Aluminium?
A project log for Desktop CNC Mill
A small CNC mill using a Dremel and as much stuff as possible from the local hardware store.
deadpangolddeadpangold • 01/15/2026 at 23:25•0 Comments
I spent today testing if this CNC-Dremel could mill aluminium. Specifically I'd like to mill (instead of hand file) these odd shaped holes that are needed in front-panels of electronics enclosures.
I'm trying terminal posts first - two slightly different sizes.
  1. Good smaller fit.
  2. Too big.
  3. Clamping failed.
  4. Good larger fit.
On the positive side: No tedious filing. On the negative side: Each hole takes almost an hour.
It's do-able but I can tell that the forces are almost too much.
