A way to upload legacy passwords to the device
A project log for Key Pass
Keychain USB multiple password manager/generator/injector
danjovicdanjovic 10/28/2015 at 13:350 Comments
I am still wondering about how to upload legacy passwords to the device.
Initially I've considered using a bootloader, and that would also allow me to update the firmware, but this approach has its drawbacks: It requires installing libusb drivers and avrdude prior to the the first use.
Then I thought on an alternative solution: Use the LED states (lit/unlit) as clock and data lines, for instance:
NUM LOCK - DATA 0
CAPS LOCK - DATA 1
SCROLL LOCK - CLOCK
Then at every change on SCROLL LOCK I could sample 2 bits of data. Doing the math, for 16 passwords of 12 characters with a 6 bit wide character set I would need 16 * 12 * 6 = 1152 bits or 576 state changes. If I could do 20 changes per second (it's a guess) then it would take me half a minute to upload all the passwords.
Not bad!
