Digital Voting Machine using PIC Microcontroller
Get this project with step by step pictures: http://www.pictutorial.net/2015/06/digital-voting-machine-using-pic-microcontroller.html
Generally Digital Voting Machine is one kind of microcontroller based machine which can be performed in election . Once i had made Digital Voting Machine and i was in 5th semester . Today I am going to share an upgrade version of it . Here in this, i used EEPROM of PIC 18f2550 so that data can be saved from electricity failure . This Digital Voting Machine conains 6 buttons for operations and two LED for notification. Candidate Category Button : Button_RA0 : Candidate_1 . Button_RA1 : Candidate_2 . Button_RA2 : Candidate_3 . Controling Button : Button_RA4 : Control Button. Status View Button : Button_RC2 : View Status Button. Result Button : Button_RA3 : Final Result Button. ***Controling Button : Get this project with step by step pictures and all details here : <a href="http://www.pictutorial.net/2015/06/digital-voting-machine-using-pic-microco" target="_blank">http://www.pictutorial.net/2015/06/digital-voting-machine-using-pic-microco</a>
  • 1
    Step 1
    This is the main head of all other buttons . Without having permission
    of this button ,any button can't perform . Without permission it's
    instructions will not be taken . This will be in the presiding officer's
    room .Once he will press the button and all other buttons will be
    permitted to perform for one time . If any key or button will be pressed
    , it will perform for one time and it will disable the system to take
    vote . So , one person will be able to vote for one time & voter
    will not be able to do that without permission of PO . The video will
    make clear about this .
  • 2
    Step 2
  • 3
    Step 3
    ***Status View Button :
    For security we are hiding the voting status from voter and Only PO can
    view this . At first PO have to press "Control Button " and LED 1 turns
    on . Then will have to press "View Status" button and current status
    will be shown only for a little time before getting back to the previous
    stage with turning on LED2.
View all 7 instructions
