1Step 1
***Controling Button :
This is the main head of all other buttons . Without having permission
of this button ,any button can't perform . Without permission it's
instructions will not be taken . This will be in the presiding officer's
room .Once he will press the button and all other buttons will be
permitted to perform for one time . If any key or button will be pressed
, it will perform for one time and it will disable the system to take
vote . So , one person will be able to vote for one time & voter
will not be able to do that without permission of PO . The video will
make clear about this .
2Step 2
3Step 3
***Status View Button :
For security we are hiding the voting status from voter and Only PO can
view this . At first PO have to press "Control Button " and LED 1 turns
on . Then will have to press "View Status" button and current status
will be shown only for a little time before getting back to the previous
stage with turning on LED2.
4Step 4
*** Result Button :
When OP decide to publish who is winner , he just need to press "control button" and after that need to press Final Result Button . After Showing result , it will be reset and all data will be erased .
5Step 5
***Candidate Category Button :
When control button gives permission , only one of "candidate button
category" buttons can perform, only for one time . After performing,
this will disable the system . Generally these buttons are incremented
by one during each action .
***LED 1 & LED 2 :
6Step 6Source Code :
sbit LCD_RS at RB7_bit; sbit LCD_EN at RB6_bit; sbit LCD_D4 at RB5_bit; sbit LCD_D5 at RB4_bit; sbit LCD_D6 at RB3_bit; sbit LCD_D7 at RB2_bit; sbit LCD_RS_Direction at TRISB7_bit; sbit LCD_EN_Direction at TRISB6_bit; sbit LCD_D4_Direction at TRISB5_bit; sbit LCD_D5_Direction at TRISB4_bit; sbit LCD_D6_Direction at TRISB3_bit; sbit LCD_D7_Direction at TRISB2_bit; // End LCD module connections short dat_can1=0,dat_can2=0,dat_can3=0,con=4; char txt[]=" "; char txt1[]="htp://www.pictutorial.net"; char txt2[]=" Digital Voting Machine"; int i=0,j=0,chk=10; char c1i='0',c1j='0',c1k='0'; char c2i,c2j,c2k; char c3i,c3j,c3k; int can_1adrs =15; // Keeping memory address for Candidate 1 int can_2adrs =19; // Keeping memory address for Candidate 2 int can_3adrs = 29; // Keeping memory address for Candidate 3 int chkk = 33,aq=0,b=0,aa=0,bb=0,cc=0; char thirdchar(short dk){ ////find third Char of Short Data aq=dk/100; aa=aq*100; aa=dk-aa; if(aq==0) { aa=dk; return '0'; } if(aq==1) return '1'; if(aq==2) return '2'; if(aq==3) return '3'; if(aq==4) return '4'; if(aq==5) return '5'; if(aq==6) return '6'; if(aq==7) return '7'; if(aq==8) return '8'; if(aq==9) return '9'; } char secondchar(short dk){ ////find Second Char of Short Data b=aa/10; bb=b*10; bb=aa-bb; if(b==0) { bb=dk; return '0'; } if(b==1) return '1'; if(b==2) return '2'; if(b==3) return '3'; if(b==4) return '4'; if(b==5) return '5'; if(b==6) return '6'; if(b==7) return '7'; if(b==8) return '8'; if(b==9) return '9'; } char firstchar(short dk){ ////find first Char of Short Data if(bb==0) return '0'; if(bb==1) return '1'; if(bb==2) return '2'; if(bb==3) return '3'; if(bb==4) return '4'; if(bb==5) return '5'; if(bb==6) return '6'; if(bb==7) return '7'; if(bb==8) return '8'; if(bb==9) return '9'; } void main() { ADCON1=0x0F; CMCON=7; TRISA.F0=1; TRISA.F1=1; TRISA.F2=1; TRISA.F3=1; TRISA.F4=1; TRISC.F0=0; TRISC.F1=0; TRISC.F2=1; Lcd_Init(); Lcd_Cmd(_LCD_CLEAR); // Clear display Lcd_Cmd(_LCD_CURSOR_OFF); /////////////////////// Lcd Scroling Display Start for(i=0;i<19;i++){ Lcd_Out(1,1,txt1); Lcd_Out(2,1,txt2); Lcd_Cmd(_LCD_SHIFT_LEFT); delay_ms(200); } Lcd_Cmd(_LCD_CLEAR); /////////////////////// Lcd Scroling Display End for(j=0;j<16;j++){ Lcd_Cmd(_LCD_CLEAR); txt[j]='.'; Lcd_Out(1,1," Starting..."); Lcd_Out(2,1,txt); delay_ms(300); } dat_can1 = EEPROM_Read(can_1adrs); // reading previous data if avail able for Candidate 1 c1i=thirdchar(dat_can1); ///third c1j=secondchar(dat_can1); //second c1k=firstchar(dat_can1); //first //// these functions should be called with this structure /// I used this , because MikroC's short to str conversion didn't work . dat_can2=EEPROM_Read(can_2adrs); // reading previous data if avail able for Candidate 2 c2i=thirdchar(dat_can2); c2j=secondchar(dat_can1); c2k=firstchar(dat_can1); dat_can3=EEPROM_Read(can_3adrs); // reading previous data if avail able for Candidate 2 c3i=thirdchar(dat_can3); c3j=secondchar(dat_can1); c3k=firstchar(dat_can1); Lcd_Cmd(_LCD_CLEAR); if(dat_can3<=0){ // check if it runs for the first time , then set data null or 0 EEPROM_Write(can_3adrs,0); dat_can3=EEPROM_Read(can_3adrs); } if(dat_can2<=0){ // check if it runs for the first time , then set data null or 0 EEPROM_Write(can_2adrs,0); dat_can2=EEPROM_Read(can_2adrs); } if(dat_can1<=0){ // check if it runs for the first time , then set data null or 0 EEPROM_Write(can_1adrs,0); dat_can1=EEPROM_Read(can_1adrs); } while(1){ c1i=thirdchar(dat_can1); // It is taking the last update data for Candidate 1 c1j=secondchar(dat_can1); c1k=firstchar(dat_can1); c2i=thirdchar(dat_can2); // It is taking the last update data for Candidate 2 c2j=secondchar(dat_can2); c2k=firstchar(dat_can2); c3i=thirdchar(dat_can3); // It is taking the last update data for Candidate 3 c3j=secondchar(dat_can3); c3k=firstchar(dat_can3); Lcd_Out(1,1,"C_1 C_2 C_3"); Lcd_Chr(2,1,'*'); Lcd_Chr(2,2,'*'); Lcd_Chr(2,3,'*'); Lcd_Chr(2,6,'*'); Lcd_Chr(2,7,'*'); Lcd_Chr(2,8,'*'); Lcd_Chr(2,11,'*'); Lcd_Chr(2,12,'*'); Lcd_Chr(2,13,'*'); if(PORTA.F4==0){ // if control button is pressed , it enables voting. con=3; } if(con!=3){ // if control button is not pressed ,naturally it disables voting. Lcd_Out(2,15,"DV"); PORTC.F0=0; PORTC.F1=1; //LED2 is on } while(con==3){ // if control button is pressed , it enables voting. Lcd_Out(2,15,"EV"); PORTC.F0=1; //LED1 is on PORTC.F1=0; if(PORTC.F2==0){ // when view status button is pressed Lcd_Chr(2,1,c1i); Lcd_Chr(2,2,c1j); Lcd_Chr(2,3,c1k); Lcd_Chr(2,6,c2i); Lcd_Chr(2,7,c2j); Lcd_Chr(2,8,c2k); Lcd_Chr(2,11,c3i); Lcd_Chr(2,12,c3j); Lcd_Chr(2,13,c3k); delay_ms(4000); con=5; // con=5 makes disable voting } if(PORTA.F0==0){ dat_can1=dat_can1+1; // Candidate 1 variable is incrementing . EEPROM_Write(can_1adrs,dat_can1); // writing the incremented value on EEPROM for Candidate 1 con=5; // con=5 makes disable voting } if(PORTA.F1==0){ dat_can2=dat_can2+1; // Candidate 2 variable is incrementing . EEPROM_Write(can_2adrs,dat_can2); // writing the incremented value on EEPROM for Candidate 2 con=5; // con=5 makes disable voting } if(PORTA.F2==0){ dat_can3=dat_can3+1; // Candidate 3 variable is incrementing . EEPROM_Write(can_3adrs,dat_can3); // writing the incremented value on EEPROM for Candidate 3 con=5; // con=5 makes disable voting } if(PORTA.F3==0){ // If Result Button is pressed . Lcd_Cmd(_LCD_CLEAR); for(j=1;j<17;j++){ Lcd_Out(1,1," Calculating..."); Lcd_Out(2,j,"."); delay_ms(200); } if(dat_can2>dat_can1&&dat_can2>dat_can3){ Lcd_Cmd(_LCD_CLEAR); Lcd_Out(1,1,"Winner is C_2"); Lcd_Out(2,1,"Congratulation!!"); delay_ms(5000); Lcd_Out(1,1,"Winner is C_2"); Lcd_Out(2,1,"He got ="); delay_ms(5000); Lcd_Cmd(_LCD_CLEAR); dat_can2=0; //Erasing All Datas dat_can1=0; dat_can3=0; EEPROM_Write(can_1adrs,0); EEPROM_Write(can_2adrs,0); EEPROM_Write(can_3adrs,0); } else if(dat_can1>dat_can2&&dat_can1>dat_can3){ Lcd_Cmd(_LCD_CLEAR); Lcd_Out(1,1,"Winner is C_1"); Lcd_Out(2,1,"Congratulation!!"); delay_ms(5000); Lcd_Cmd(_LCD_CLEAR); dat_can2=0; dat_can1=0; dat_can3=0; EEPROM_Write(can_1adrs,0); EEPROM_Write(can_2adrs,0); EEPROM_Write(can_3adrs,0); } else if(dat_can3>dat_can1&&dat_can3>dat_can2){ Lcd_Cmd(_LCD_CLEAR); Lcd_Out(1,1,"Winner is C_3"); Lcd_Out(2,1,"Congratulation!!"); delay_ms(5000); Lcd_Cmd(_LCD_CLEAR); dat_can2=0; dat_can1=0; dat_can3=0; EEPROM_Write(can_1adrs,0); EEPROM_Write(can_2adrs,0); EEPROM_Write(can_3adrs,0); } else{ Lcd_Cmd(_LCD_CLEAR); Lcd_Out(1,1,"Something is"); Lcd_Out(2,1,"Worng!!!"); delay_ms(1000); Lcd_Cmd(_LCD_CLEAR); } con=5; } } } }
Circuit Diagram in Proteus:nt chkk = 33,aq=0,b=0,aa=0,bb=0,cc=0; char thirdchar(short dk){ ////find third Char of Short Data aq=dk/100; aa=aq*100; aa=dk-aa; if(aq==0) { aa=dk; return '0'; } if(aq==1) return '1'; if(aq==2) return '2'; if(aq==3) return '3'; if(aq==4) return '4'; if(aq==5) return '5'; if(aq==6) return '6'; if(aq==7) return '7'; if(aq==8) return '8'; if(aq==9) return '9'; } char secondchar(short dk){ ////find Second Char of Short Data b=aa/10; bb=b*10; bb=aa-bb; if(b==0) { bb=dk; return '0'; } if(b==1) return '1'; if(b==2) return '2'; if(b==3) return '3'; if(b==4) return '4'; if(b==5) return '5'; if(b==6) return '6'; if(b==7) return '7'; if(b==8) return '8'; if(b==9) return '9'; } char firstchar(short dk){ ////find first Char of Short Data if(bb==0) return '0'; if(bb==1) return '1'; if(bb==2) return '2'; if(bb==3) return '3'; if(bb==4) return '4'; if(bb==5) return '5'; if(bb==6) return '6'; if(bb==7) return '7'; if(bb==8) return '8'; if(bb==9) return '9'; } void main() { ADCON1=0x0F; CMCON=7; TRISA.F0=1; TRISA.F1=1; TRISA.F2=1; TRISA.F3=1; TRISA.F4=1; TRISC.F0=0; TRISC.F1=0; TRISC.F2=1; Lcd_Init(); Lcd_Cmd(_LCD_CLEAR); // Clear display Lcd_Cmd(_LCD_CURSOR_OFF); /////////////////////// Lcd Scroling Display Start for(i=0;i<19;i++){ Lcd_Out(1,1,txt1); Lcd_Out(2,1,txt2); Lcd_Cmd(_LCD_SHIFT_LEFT); delay_ms(200); } Lcd_Cmd(_LCD_CLEAR); /////////////////////// Lcd Scroling Display End for(j=0;j<16;j++){ Lcd_Cmd(_LCD_CLEAR); txt[j]='.'; Lcd_Out(1,1," Starting..."); Lcd_Out(2,1,txt); delay_ms(300); } dat_can1 = EEPROM_Read(can_1adrs); // reading previous data if avail able for Candidate 1 c1i=thirdchar(dat_can1); ///third c1j=secondchar(dat_can1); //second c1k=firstchar(dat_can1); //first //// these functions should be called with this structure /// I used this , because MikroC's short to str conversion didn't work . dat_can2=EEPROM_Read(can_2adrs); // reading previous data if avail able for Candidate 2 c2i=thirdchar(dat_can2); c2j=secondchar(dat_can1); c2k=firstchar(dat_can1); dat_can3=EEPROM_Read(can_3adrs); // reading previous data if avail able for Candidate 2 c3i=thirdchar(dat_can3); c3j=secondchar(dat_can1); c3k=firstchar(dat_can1); Lcd_Cmd(_LCD_CLEAR); if(dat_can3<=0){ // check if it runs for the first time , then set data null or 0 EEPROM_Write(can_3adrs,0); dat_can3=EEPROM_Read(can_3adrs); } if(dat_can2<=0){ // check if it runs for the first time , then set data null or 0 EEPROM_Write(can_2adrs,0); dat_can2=EEPROM_Read(can_2adrs); } if(dat_can1<=0){ // check if it runs for the first time , then set data null or 0 EEPROM_Write(can_1adrs,0); dat_can1=EEPROM_Read(can_1adrs); } while(1){ c1i=thirdchar(dat_can1); // It is taking the last update data for Candidate 1 c1j=secondchar(dat_can1); c1k=firstchar(dat_can1); c2i=thirdchar(dat_can2); // It is taking the last update data for Candidate 2 c2j=secondchar(dat_can2); c2k=firstchar(dat_can2); c3i=thirdchar(dat_can3); // It is taking the last update data for Candidate 3 c3j=secondchar(dat_can3); c3k=firstchar(dat_can3); Lcd_Out(1,1,"C_1 C_2 C_3"); Lcd_Chr(2,1,'*'); Lcd_Chr(2,2,'*'); Lcd_Chr(2,3,'*'); Lcd_Chr(2,6,'*'); Lcd_Chr(2,7,'*'); Lcd_Chr(2,8,'*'); Lcd_Chr(2,11,'*'); Lcd_Chr(2,12,'*'); Lcd_Chr(2,13,'*'); if(PORTA.F4==0){ // if control button is pressed , it enables voting. con=3; } if(con!=3){ // if control button is not pressed ,naturally it disables voting. Lcd_Out(2,15,"DV"); PORTC.F0=0; PORTC.F1=1; //LED2 is on } while(con==3){ // if control button is pressed , it enables voting. Lcd_Out(2,15,"EV"); PORTC.F0=1; //LED1 is on PORTC.F1=0; if(PORTC.F2==0){ // when view status button is pressed Lcd_Chr(2,1,c1i); Lcd_Chr(2,2,c1j); Lcd_Chr(2,3,c1k); Lcd_Chr(2,6,c2i); Lcd_Chr(2,7,c2j); Lcd_Chr(2,8,c2k); Lcd_Chr(2,11,c3i); Lcd_Chr(2,12,c3j); Lcd_Chr(2,13,c3k); delay_ms(4000); con=5; // con=5 makes disable voting } if(PORTA.F0==0){ dat_can1=dat_can1+1; // Candidate 1 variable is incrementing . EEPROM_Write(can_1adrs,dat_can1); // writing the incremented value on EEPROM for Candidate 1 con=5; // con=5 makes disable voting } if(PORTA.F1==0){ dat_can2=dat_can2+1; // Candidate 2 variable is incrementing . EEPROM_Write(can_2adrs,dat_can2); // writing the incremented value on EEPROM for Candidate 2 con=5; // con=5 makes disable voting } if(PORTA.F2==0){ dat_can3=dat_can3+1; // Candidate 3 variable is incrementing . EEPROM_Write(can_3adrs,dat_can3); // writing the incremented value on EEPROM for Candidate 3 con=5; // con=5 makes disable voting } if(PORTA.F3==0){ // If Result Button is pressed . Lcd_Cmd(_LCD_CLEAR); for(j=1;j<17;j++){ Lcd_Out(1,1," Calculating..."); Lcd_Out(2,j,"."); delay_ms(200); } if(dat_can2>dat_can1&&dat_can2>dat_can3){ Lcd_Cmd(_LCD_CLEAR); Lcd_Out(1,1,"Winner is C_2"); Lcd_Out(2,1,"Congratulation!!"); delay_ms(5000); Lcd_Out(1,1,"Winner is C_2"); Lcd_Out(2,1,"He got ="); delay_ms(5000); Lcd_Cmd(_LCD_CLEAR); dat_can2=0; //Erasing All Datas dat_can1=0; dat_can3=0; EEPROM_Write(can_1adrs,0); EEPROM_Write(can_2adrs,0); EEPROM_Write(can_3adrs,0); } else if(dat_can1>dat_can2&&dat_can1>dat_can3){ Lcd_Cmd(_LCD_CLEAR); Lcd_Out(1,1,"Winner is C_1"); Lcd_Out(2,1,"Congratulation!!"); delay_ms(5000); Lcd_Cmd(_LCD_CLEAR); dat_can2=0; dat_can1=0; dat_can3=0; EEPROM_Write(can_1adrs,0); EEPROM_Write(can_2adrs,0); EEPROM_Write(can_3adrs,0); } else if(dat_can3>dat_can1&&dat_can3>dat_can2){ Lcd_Cmd(_LCD_CLEAR); Lcd_Out(1,1,"Winner is C_3"); Lcd_Out(2,1,"Congratulation!!"); delay_ms(5000); Lcd_Cmd(_LCD_CLEAR); dat_can2=0; dat_can1=0; dat_can3=0; EEPROM_Write(can_1adrs,0); EEPROM_Write(can_2adrs,0); EEPROM_Write(can_3adrs,0); } else{ Lcd_Cmd(_LCD_CLEAR); Lcd_Out(1,1,"Something is"); Lcd_Out(2,1,"Worng!!!"); delay_ms(1000); Lcd_Cmd(_LCD_CLEAR); } con=5; } } } }
7Step 7
Video of Digital Voting Machine in Practical :
Download This Project Simply Just click on the "Skip Ad" and you will get the download option. Thank You!!
