NRFBee
XBee compatible board using NRF24L01
NRFBee includes NRF24L01 module and Atmega328. NRFBee is in shape of XBee and also XBee pin compatible which allows using NRF24L01 via 2 pin UART instead of 6 pin SPI. Configuration with AT Commands and custom firmware uploading is available.
  • 1 × NRF24L01
  • 1 × Atmega328 Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × 8mhz Resonator
  • 1 × 10K Resistor (SMD 0603)
  • 2 × 330 Resistor (SMD 0603)
View all 10 components
Blecky wrote 12/07/2015 at 01:37 point
Just a friendly reminder to please upload your design documents by 23:59 UTC on Dec 8, 2015 to be in the running for #The Square Inch Project! (You seem to be missing your PCB design files; gerbers etc.).
alpha_ninja wrote 12/02/2015 at 00:42 point
This is your one-week reminder to upload design documents: https://hackaday.io/project/7813-the-square-inch-project/log/28566-design-deadline
2.9k
43
5
Project Owner Contributor
PiMasher
joshua.vaderjoshua.vader
