Virtual functions are not a problem for embedded systems. Their raw performance nearly matches normal C calls and in an overall system performance can actually be a faster. CODE CRAFT – EMBEDDING C++: TIMING VIRTUAL FUNCTIONS measures C function calls, C pointer to function calls, and C++ virtual calls and finds them taking the same amount of time, for pratical purposes.
Rud Merriam
