Pro Trinket USB Keyboard by Stefan Lochbrunner
A project log for Me building projects from hackaday.io
This is where I build and talk about projects designed by the great people of this community.
davedarkodavedarko 10/28/2015 at 18:326 Comments
#Pro Trinket USB Keyboard by @Stefan Lochbrunner
[2015-10-31] started building
[2015-11-07] encoders are in, finally got it working (video proof)
When [Stefan] asked for one of my #Ignore this ESP8266 board 's, he send me one of his #Breadboard Widgets and I also asked for one of his Pro Trinket boards, since I had one or two trinkets in my drawer.
I ordered the parts needed, which was in fact everything except the trinket pro. Looking through eBay I found 12x12 mm tact switches with optional caps on them. Because I like purple, shapeways is able to print purple now and I found this file: http://www.thingiverse.com/thing:493729 that I changed a bit to make the caps bigger (12x12 instead 10x10) I am now in possession of this beauty. It is not soldered yet, but I love the look so far!
Build log
The LEDs came yesterday, so I could finally start building this beauty. I managed to solder the yellow and orange LEDs upside down - so my fix was to solder more LEDs on top of them :D I didn't get the keyboard functions to work though :( Gotta fiddle around with arduino libs and versions again.
Here are the button cap files:
http://www.thingiverse.com/thing:1097850
UPDATE
Thanks to Stefan who send me this link http://www.freebsddiary.org/APC/usb_hid_usages.php I found out that if you use 0xB3 and 0xB4 instead of the 0xB5 and 0xB6 for next and previous song commands, that you don't have to have the window active to switch tracks. At least in my microcosmos, where we also found out that TrinketHidCombo.isConnected() doesn't work.
davedarko wrote 11/07/2015 at 11:01 point
@Stefan Lochbrunner how did you install the library? I'm stuck with the software...
//USB
  TIMSK0&=!(1<  TrinketHidCombo.begin();
while(!TrinketHidCombo.isConnected()){
    TrinketHidCombo.poll();
After that I don't get any LEDs showing the mode.
Stefan Lochbrunner wrote 11/07/2015 at 12:45 point
does it show up as a keyboard on your computer?
davedarko wrote 11/07/2015 at 12:47 point
it shows as "Pro Trinket HID Combo" in the USB tree on my mac.
Stefan Lochbrunner wrote 11/07/2015 at 12:53 point
Ok, then the library is probably installed correctly and on the Trinket it should be connected and should have jumped past that while loop. You're using v4, right?
davedarko wrote 11/07/2015 at 12:56 point
let's solve this via PM and I'll write the results here.
davedarko wrote 11/07/2015 at 14:13 point
Solved for me by removing "TrinketHidCombo.isConnected()" from the code.
