1Step 1
Install Arduino IDE 1.6.5+. You must install version 1.6.5 or higher in order to participate in this workshop. You will need an internet connection for these steps!
2Step 2
Add the ESP8266 Arduino Add-on. Add the following text to your Additional Boards Manager URLs under File> Preferences:
http://arduino.esp8266.com/stable/package_esp8266com_index.json -
3Step 3
Double check that you have properly installed the ESP8266 files by going to Tools>Board>Boards Manager. Search for ESP8266 and verify that the package shows as Installed.
4Step 4
Please download the .zip Blynk library. You can find the repository here.
5Step 5
Install the Blynk app from the Google Play or Apple Store. Sign up for an account - it's free!
6Step 6
Please make sure you have FTDI drivers installed if applicable for your computer (typically required for Windows machines).
7Step 7
Download the .zip Phant library. The repo is here.
8Step 8
Download the example sketches here.
Toni Klopfenstein
