rev2 is working!
A project log for PICTIL
Remake of the TIL311 hex LED display with recent technology.
alexAlex 05/11/2016 at 19:597 Comments
Today the missing parts for finishing rev2 arrived. And it's also working. Also the blank circuit is working! Here a first image. I will take better ones soon.
The changed firmware is now also available in the bit bucket repository. So in combination with the link to the board at OSH park. Everyone with decent soldering skills can build his own. If you do that please post some pictures.
deʃhipu wrote 05/11/2016 at 22:33 point
Looking at this I wonder if a version with castellated pads for the headers would make sense. You could still solder pins on the edges, but you could also just put in on your PCB directly like an SMD component. Yes, I realize there are components on the other side of the board (and that moving them all on one side is not realistic), but you could still use only short pieces of wire...
Alex wrote 05/12/2016 at 09:55 point
mh.. never thought about that. But there is another reason why this will getting difficult: At least in this revision I need the PCB on the edges to run traces there.
Yann Guidon / YGDES wrote 05/11/2016 at 21:20 point
Where can I order them ? :-D
Alex wrote 05/11/2016 at 21:57 point
hehe every time the same question.. (just kidding).
But thee will be maybe a possibility to order them later this year. But for now the "production" of these is not fast enough. And I do only have 3 PCBs of rev2. I should make some panel and stencil for it.
Yann Guidon / YGDES wrote 05/11/2016 at 22:15 point
until then I have some TIL311 in stock... but they get too hot :-(
Alex wrote 05/11/2016 at 21:59 point
By the way I did measured the power consumption today and it consumes 5
times less and is brighter. More in a new log tomorrow.
Yann Guidon / YGDES wrote 05/11/2016 at 22:14 point
awesome !
