• 1
    Step 1
    First you need to identify the controller lines and solder 2 wires from the switch
  • 2
    Step 2
    I drilled a hole through the top of the controller and sent the 2 lines out from the opening
  • 3
    Step 3
    When all is done it should look somehting like this. The fog machine requires a little bit to warm up and thats why they have a momentary switch.
