Teeny Tiny
Data logger using Atmel Tiny85
I am trying to design a board using Atmels' Tiny85. As a secondary goal, I'm going to try to cram as much as I can unto it.
(The accompanying image is a rough first draft)
In order to be a worthwhile device to log any sort of data, it will need a few properties:
1. Data storage (EEPROM or µSD)
2. Power Management (Battery and/or solar)
3. RTC for timestamping
In an effort to make it easy/cheap to fabricate:
1. Limit to 4 layers (preferably 2)
2. No custom parts (except PCB)
3. Limit the number of very small parts (eg 0402 components).
In an effort to make environmentally safe:
1. Use only RoHS components/techniques
2. No lead/halides or other dangerous chemicals
  • 1 × ATtiny85 Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × TPS63060 Power Management ICs / Switching Regulators and Controllers
  • 1 × MCP73831 Power Management ICs / Power Supply Support
  • 1 × DS1307 I2C compatable Real-Time-Clock (RTC).
  • 1 × JST Vertical Connector Connector for Battery
View all 6 components
  • Second Log
    davidedwardlivermore11/06/2015 at 01:04 0 comments
    Still working out some of the details for the circuit. Currently working out the best way to get the data off of EEPROM (if I go that route). I'm inclined to use EEPROM over uSD simply because the I2C interface on the Tiny allows me to operate a few other things (such as power management).
    Any thoughts?
  • First Log Entry
    davidedwardlivermore11/02/2015 at 01:59 0 comments
    Doing a few things at the moment:
    1. Prototyping what I can (which is limited since I don't have a working ATtiny, just an Arduino).
    2. Reconsidering the DC power jack in favour of a voltage regulator and a couple pins; the power jack takes up a LOT of real estate.
    3. Looking through SparkFun and DigiKey to order some parts.
View all 2 project logs
alpha_ninja wrote 11/06/2015 at 16:00 point
Hi! You could probably enter #The Square Inch Project with this if you'd like to :)
