Finally programmable
A project log for DIL-Duino
A complete Arduino environment in a DIL-8 form factor based on the DigiSpark Hardware
daniel-griehaberDaniel Grießhaber 12/22/2015 at 21:570 Comments
As I wrote, I received the boards quite a while back, but I have to admit, I really had a hard time getting them assembled.
The first I tried with the stencils I ordered from OSH Park. This really did work great but I managed to put on the pin headers the wrong way around and really fucked up the USB mini jack so the board was on functional.
My next try was 6 days after the first but I did forget to put the solder paste back into the freezer after using it the last time so I could not apply it through the stencil (it basically was just clogging the stencil).
After that I tried to use solder paste without the stencil and it looked quite good, but I think I've shortened some pins on the QFN because I was not able to program it.
Today (as the deadline for the sqare inch contest moved closer :)) I finally gave it another try. This time I did not use solder paste but normal 40/60 and pre tinned all pads with it. then I put on the QFN and applied head with my soldering iron from the bottom. I then used the hot-air gun to reflow the solder.
This time it worked and I finally can program the chip :)
programming the chip with an Arduino Leonardo
I tested the programming and reset circuit using the build-in LED on PB2:
