After losing a Light Handlebar Mount to wear and tear I found myself in urgent need of a replacement. Having studied a few schemes I came upon this one:
<a href="http://www.bikehacks.com/bikehacks/2010/06/mini-maglite-handlebar-light-hack.html" target="_blank">http://www.bikehacks.com/bikehacks/2010/06/mini-maglite-handlebar-light-hack.html</a>
which I found the best, given the low part count (1).
I had no old inner tubes lying around so the next and nearest thing was silicone tubing, which turned out ok given that a couple of loops around the handlebar provide some padding between handlebar and light plus a half shoelace knot provides a quick release mechanism.
This setup received a royal pounding and come out as it went in without any tilting so I judged it worthy of documenting.
Details
Another Minimal Engineering attempt.
Components
1×
Silicone Tubbing
720mm (2' 4") Ø4.8 external diameter Ø1.8 internal diameter or similar
