Ver. 1
A project log for PCB Business Card
because paper is too easy
alexpufferalex.puffer 05/10/2016 at 23:230 Comments
With everything laid out in KiCad and boards ordered from OSH Park, I assembled the first card in my toaster oven. The touch plates didn't seem to do much. Most of the time, the LED comes on when the battery is inserted and then turns off if the OFF touch plate or anywhere on GND is touched. The ON touch plate does absolutely nothing. I don't have a test bench right now so there's not too much I feel like doing to see what the deal is, but it's still a pretty rad business card to give away.
Fig. 1 - The circuit: 555 touch-plate design from http://www.electroschematics.com/12184/555-ic-tutorial/
Fig. 2 - Completed Board - the pads don't look gold, but they are
Fig. 3 - Assembled board, pre-cleanup
