• New revision arrived
    WooDWorkeR04/13/2016 at 12:03 0 comments
    Finally i have them in my Hands. The new revision of the protothing. As the last revision also ordered at DirtyPCB's the 50x50mm PCB Protopack - got 11 of the +/-10 boards they say. I really love the fact that i do not need to pay extra for the black soldermask that is maybe not always the best choice but for a c-base board needed. The print is on the top is a tiny bit off but nothing bad. Will order again.
    The first thing i try is to create a small Arduino clone with regulated 5 V just to see how good the idea with the power section at the bottom works.
    And as the last batch, i will also spread them to c-base members to see what they will come up with. Maybe if all the other that will get a board say this is good i will order a bigger batch.
  • Ordered new revision
    WooDWorkeR03/13/2016 at 18:28 0 comments
    New revision ordered at DirtyPCBs, now the waiting begins.
    The Voltage regulator part at the bottom got a little change, as it no "supports" any 3 legged voltage regulator.
    And now enough PIN rows to support an ATMega(16|32)8 or any other 28 pin DIP.
  • Update to rev-C
    WooDWorkeR11/10/2015 at 16:38 0 comments
    Worked a bit on rev-C (big C)
    • Added support for 7805 voltage regulator at the bottom
    • Ground and Regulated Voltage bars at the side
    • Now with DIP28 footprint
    • bigger holes for strain relif
