New revision arrived
04/13/2016 at 12:03 • 0 commentsFinally i have them in my Hands. The new revision of the protothing. As the last revision also ordered at DirtyPCB's the 50x50mm PCB Protopack - got 11 of the +/-10 boards they say. I really love the fact that i do not need to pay extra for the black soldermask that is maybe not always the best choice but for a c-base board needed. The print is on the top is a tiny bit off but nothing bad. Will order again.
The first thing i try is to create a small Arduino clone with regulated 5 V just to see how good the idea with the power section at the bottom works.
And as the last batch, i will also spread them to c-base members to see what they will come up with. Maybe if all the other that will get a board say this is good i will order a bigger batch.
Ordered new revision
03/13/2016 at 18:28 • 0 commentsNew revision ordered at DirtyPCBs, now the waiting begins.
The Voltage regulator part at the bottom got a little change, as it no "supports" any 3 legged voltage regulator.
And now enough PIN rows to support an ATMega(16|32)8 or any other 28 pin DIP.
Update to rev-C
11/10/2015 at 16:38 • 0 commentsWorked a bit on rev-C (big C)
- Added support for 7805 voltage regulator at the bottom
- Ground and Regulated Voltage bars at the side
- Now with DIP28 footprint
- bigger holes for strain relif
