4 layer PCB designed but not tested
A project log for 3DPCB - Smoothieboard Compatible Driver PCB
The 3DPCB is a Smoothie-compatible PCB designed to fit "normal-sized" 3D printer driver boards.
christian-lercheChristian Lerche 08/16/2016 at 09:020 Comments
https://github.com/ChristianLerche/3DPCB-4LAYER
It's 4 layer so heat transfers will be better.
Minor updates to the design.
When I have a tested board, I will write a new log.
