Epoxies
A project log for BorgCube ROV
Underwater robots!
tim-wilkinsonTim Wilkinson 01/16/2016 at 01:260 Comments
Some of the ROV components need to be encased in epoxy to protect them from the water (e.g. the lights, the electronics for the manipulator, and the ESCs). I tried out three different epoxies:
My ideal is something that's transparent, thermally conductive, electorally insulating, easy to mix and pour without bubbles forming, and - in case of problems - reversible. To try these out, I mixed up each epoxy and cast a small amount in acrylic boxes. I also mixed each epoxy again, but this time I vacuumed the epoxy before pouring in an attempt to reduce bubbles.
The photo below show the results:
On the left are the vacuumed samples, the non-vacuumed on the right. From top to bottom the epoxy are MG, West, and QSil. For my purposes, the QSil is the best: it's completely transparent and pours, even without vacuuming, without bubbles forming. As an added bonus (hopefully!) it forms a hard gel but does not go completely solid; in theory and with work it should be possible to remove. The only, minor, downside is that it takes over 24 hours to fully cure. Don't be in the rush.
