Main Daughter Board: Update 1
A project log for BorgCube ROV
Underwater robots!
tim-wilkinsonTim Wilkinson 01/21/2016 at 22:201 Comment
Received the main daughter board PCB yesterday:
And here it is populated:
There were a couple of mistakes on the board (hence the wires you can see):
Otherwise everything checks out, including all the power monitors, temperature/humidity/pressure sensor, IMU and PWM controller for the vision servos and lights.
Tim Wilkinson wrote 01/22/2016 at 02:45 point
Another minor issue - there should be thick copper tracks between the 'Tether-In' and 'Power-Out' connectors. This is the main path for the incoming tether power to be sent off-board to the UBEC. Not a major issue - I'll just have to solder the UBEC cables to the incoming tether directly.
