New ESC driver board
A project log for BorgCube ROV
Underwater robots!
tim-wilkinsonTim Wilkinson 05/15/2016 at 07:000 Comments
The new ESC board turned up in the mail the other day, and I had chance to populate one for testing. Each board drives 6 ESCs (I'll use two in the ROV) using the same PWM control chip as I've used before. I've also added a polyfuse for protection, and added barrel connectors which allow the Afro ESCs to plug easily into this board without modification.
