Soldering didn't work with boards from oshpark
A project log for TPS63036 breakout board
1.8...5.5V to 1.2...5.5V step-up/down converter board
christophChristoph 10/09/2017 at 11:010 Comments
It's been a while since I've been trying to solder this in #vapsy but the results we not good. It seems that the boards simply have the needed quality for this small regulator. This is not a show stopper per se, but the design is actually out of oshpark's limits (at least it was outside the limits when I ordered the board).
