New boards and soldering
A project log for LIS3DH breakout board
3D accelerometer with SPI, I2C and 3 ADC inputs
christophChristoph 12/17/2015 at 11:020 Comments
After the new (now correct) boards from OSH Park arrived I could start trying to solder the parts. 0603 passives are no problem at all, but the LGA-16 is. It's really tiny, and the pads on my board seem to be too wide, resulting in shorts between two pins on two boards:
I did my best to apply only little solder paste, equal amounts to each pad, using a kapton tape stencil:
So I asked for advice on electronics stackexchange, and the most important hint was to use a way of reflowing that allows me to poke the chip while the solder is liquid. Having no hot air gun I decided to use a hot plate. I've added my solution as an answer there, including all the details.
This time everything worked and I have a board without shorts and all pins seem to be connected:
Now I just need to find some time to write test code!
