Success!
A project log for LIS3DH breakout board
3D accelerometer with SPI, I2C and 3 ADC inputs
christophChristoph 02/08/2016 at 21:000 Comments
Finally I have a good board:
After seeking for advice in a few places, this is how I soldered the LGA package:
My explanation for why this works is quite simple: with the solder applied with an iron (just drag it across the pads), each pad will receive about the same amount of solder. This is almost impossible with paste applied manually. Having equal amounts of solder on the pads is good because each resulting joint will have the same height. With paste I had the impression that joints with a larger amount of paste tend to push the part further up than the neighbouring joint can "stretch", thus causing joints with no contact at all. Also, two adjacent pads with a large amount of paste can easily cause a short.
I tested the board with adafruit's LIS3DH library, which worked very well.
