Next steps
11/10/2015 at 15:36 • 0 comments- Add voltage select to the design [DONE]
- Design the box [DONE]
- Solder the contacts [DONE]
- Test [DONE]
- Unsolder led and replace potentiometer [DONE]
- Drill holes in the box
- Cut hollow spaces in the box
- Add heat shrink sleeves to wires
- Solder everything
- Fixate to the box
- Test
- Close box
André Wagner
