Oh... where to start...
One, and probably the major, reason why I started building this machine is that I wanted to make PCBs. Just one-offs that could be made in hour(s) instead of having to wait weeks for the boards to be delivered. Obviously I could also etch the boards and while @CNLohr makes it look so easy, to me the process is just not appealing mainly because waste disposal is a whole nother issue. So PCB mill it is (or was). Plus, it might come in handy for milling other things as well and maybe I can 'slap' an extruder on there, too, but that's probably another 2.5 years down the line ;)
Contents:
- Some links - more information and inspirations
- Electronics
- Electronics - motor control
- Mechanical 'design'* - general overview
- 'Spindle'
Stefan Lochbrunner
It came to me when I had this threaded rod with those two standoffs laying on my bench along with a small box of misc parts among which were some springs. I was just sort of playing around with these parts wanting to see how far I could compress this quite stiff spring but then something interesting happened: The spring locked the two standoffs together pretty much eliminating the backlash, although it depends on how tight the spring is compressed. Of course, as it is the standoffs aren't completely locked, especially when the rod is turning fast but that's an easy fix.
gregstephenson
Paul McClay
Alastair Young
Some years later...
How far did you get with this?
