The stepper motors seen in the main project image are salvaged from old printers. Maybe I'll write about them in more detail some other time.
To control the motors I'm using StepSticks which are really cheap on eBay and easy to use and are in turn controlled by an Uno.
As you can probalby guess from the image the Uno is running GRBL so nothing fancy here.
Stefan Lochbrunner
