2 month report
02/07/2016 at 19:47 • 0 commentsI have been charging my uv3 via USB for a couple of months now and its working great. The additon of the hole to see the charger state really helped to know if it was charaged. Overall its worked out as a nice mod to the radio.
Project completed.
11/11/2015 at 20:37 • 0 commentsThe project didnt take more than 30 minutes of time once I had the charger board. there is a lot of room in the charger case so no critical tolerances to worry about. Only a few connections to solder so this should be an easy project for even those inexperienced in soldering.
Gary
