Slides
11/17/2015 at 22:22 • 0 commentsHere are the slides from the workshop! You'll be able to find the links useful for more in depth info.
Currently printing
11/14/2015 at 23:37 • 0 commentsIf you're at the Hackaday Hardware Superconference right now, check out the model that is currently printing on the Form 2! It's in the main area next to a wall. Special thanks to FormLabs for the machine and help!
If you have made a model during / after the Antimony workshop and want to print it — let me know and we can print it
Thinking about shapes
11/13/2015 at 02:31 • 0 commentsHi everyone! Here is an introductory video with some information and thoughts prior to the workshop. Hope you'll take the chance to watch it!
Something weird happened with the audio and video not syncing up, let's call it an exercise in imagination to pretend it's not super awkward.
Building Antimony from Source
11/12/2015 at 14:22 • 2 commentsIf you want to run Antimony on Ubuntu, here is what you will need to do. These instructions are from the Antimony repository here.
1. Install QT 5.4
2. Run:
sudo apt-get install build-essential sudo apt-get install libpng-dev sudo apt-get install python3-dev sudo apt-get install libboost-all-dev sudo apt-get install libgl1-mesa-dev sudo apt-get install lemon sudo apt-get install flex
3. You might need to update the gcc compilersudo add-apt-repository ppa:ubuntu-toolchain-r/test sudo apt-get update sudo apt-get install gcc-4.9 g++-4.9 sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-4.9 60 --slave /usr/bin/g++ g++ /usr/bin/g++-4.9
4. Clone and build Antimony
git clone https://github.com/mkeeter/antimony cd antimony mkdir build cd build ~/Qt5.4.0/5.4/gcc_64/bin/qmake ../sb.pro make -j8 ./app/antimony
5. Run it
make install
I'll be running Antimony on a Mac, and have not tested the Ubuntu install. There are some tips listed at the bottom of the page here that might help if you run in to a road block while trying to build from source. If not, leave a comment and we can try to help!
