20171008_174258.jpgKnob cap replacedJPEG Image - 952.92 kB - 10/08/2017 at 23:54 |
20171008_174240.jpgKnob replacedJPEG Image - 1011.58 kB - 10/08/2017 at 23:54 |
20171008_174143.jpgInstall the finishing chrome flangeJPEG Image - 1.14 MB - 10/08/2017 at 23:54 |
20171008_174115.jpgReinstall the knob guideJPEG Image - 1.06 MB - 10/08/2017 at 23:53 |
20171008_174033.jpgReinstall the valve stem.JPEG Image - 1.44 MB - 10/08/2017 at 23:53 |
20171008_173221.jpgClean brass washer stuck onto 'bad seat' using a tweezer to install.JPEG Image - 1.52 MB - 10/08/2017 at 23:52 |
20171008_172818.jpgRTV sealant applied to cold water seat as prep for using a clean brass washer to 'resurface'JPEG Image - 1.50 MB - 10/08/2017 at 23:52 |
20171008_164216.jpgPolish cold water seat...good enough to seal.JPEG Image - 1.67 MB - 10/08/2017 at 23:51 |
20171008_164004.jpgHot water seat polished with 0.65" diameter Dremel stone, note the notch where the leak is happeningJPEG Image - 1.50 MB - 10/08/2017 at 23:50 |
20171008_163656.jpgHot water seat untreatedJPEG Image - 1.43 MB - 10/08/2017 at 23:48 |
20171008_163624.jpgCold water seat untreatedJPEG Image - 1.84 MB - 10/08/2017 at 23:48 |
JPEG Image - 1.93 MB - 10/08/2017 at 23:48 |
