Milled case: check
A project log for Magnetic Incremental Rotary Encoder
A compact solution for your closed loop positioning requirements
ottoragamottoragam 11/20/2015 at 13:592 Comments
The PCB can be mounted using the two holes next to the IC, but I also wanted to have an enclosure for the module for scenarios that demand more protection. I designed and milled a case for the PCB (relevant design files in the repo). I made the base from pine (my plan was to use acetal or polyethylene, but I didn't have any of those materials stocked). The cover is made from clear acrylic, with two of the four bolt holes drilled to accept threading with a 3 mm tap.
Here's the whole thing assembled. Notice that the IC must be facing the acrylic part.
Mounting the case onto something like a motor prevents the user from being able to see the alignment LEDs directly. This is where the acrylic cover comes into play, because it allows the light to be seen on the edge of the part.
esot.eric wrote 11/20/2015 at 17:35 point
Diggin' the LED/acryllic aspect!
ottoragam wrote 11/20/2015 at 18:05 point
Glad you like it! Btw, your commonCode certainly looks useful.
