Trouble with other joysticks.
A project log for 2 Analog Inputs for ESP8266 Without Multiplexer
Inputting 2 analog inputs into the ESP8266 without a multiplexer using just a couple of IO.
Daniel JohnsonDaniel Johnson 07/06/2017 at 15:541 Comment
After talking with Orion Robots, and him replicating this solution here, he had trouble making this work with other joysticks. This is because when moving the joystick all the way to high or low, the internal resistance of some joysticks is so low that the esp8266 isn't able to sink the current into its GPIO pin. If you experience similar issues, try using this updated schematic.
alexjensentx wrote 07/30/2017 at 23:17 point
thanks for keeping this current!
