Simplified Android app; upcoming goals
A project log for WEFT electrovibration demo board
This board is for prototyping electrotactile interactions - use an electronic signal to dynamically change the texture of a surface.
akaAKA 01/13/2016 at 17:510 Comments
tl;dr
I realized I was making two separate things in one Project, which is confusing, so I've simplified the project repo in the hopes of making it easier to jump into.
Splitting the project
I'm developing two things: one is the hobby board for WEFT, which will allow designers, prototypers, and hackers to easily integrate electrovibration into their projects. The other is a more focused device, a wearable that uses electrovibration to represent the state of your unread notifications.
This Hackaday project will be for the hobby board: the Hackaday audience is, I think, better served by focusing on that. Let me know if you disagree, and be assured, I'm still actively working on the wearable/notifications thing too!
Repo Cleanup and New Board
The github repo has been updated with a much-simpler Android app that allows the user to experiment with different waveforms, amplitudes, frequencies, and duty cycles. The board that interfaces with this app is the BLE-enabled board. Just to be clear, here's the BLE board:
The main problem with the BLE board (which I'm actively working on) is the BOM cost - it's currently just under $50, which is ridiculous. As I mentioned in a previous update, a huge amount of that cost comes from two microcontrollers, one for electrovibration and DAC stuff and one for BLE interfacing. I'm working steadily on ditching the Teensy, possibly for the RFduino or Simblee, possibly for some other appropriate microcontroller. I *really* don't want to get FCC certification, so an already-certified board is much preferred.
As the BLE board progresses, I'm realizing that it's ideal for embedding into projects but not as easy to just mess around with. The previous board I made, back at my day job, is slightly better for this. (For reference, the previous board is called "Lever" and is the handheld version that some of you got to try at the SuperConf). Here's the (old) Lever board:
So I think I'm going to start work on a new board, one that:
This will basically be a board the size of the BLE board with some better routing and, if I'm lucky, a new and more robust version of the boost converter circuit. I thought briefly about perforating the Lever board, so that you could break off the pads when you were done prototyping and were ready to embed it into your prototype, but again, that's a lot of PCB to eventually throw away...what do you think?
Onward
So to summarize, the next things on the project docket are:
OK! Am I missing anything? I'm loving the Hackaday.io interface and am very grateful that I'm getting such helpful, positive suggestions from the community - that's (one reason) why you-all rock!
