The Seeed CAN-BUS shield is up and running!
A project log for Real Scania Truck Home Simulator
The Scrapyard and Arduino make a great combination!
jeroen-van-der-veldenJeroen van der Velden 11/15/2015 at 13:200 Comments
Please don`t use the code below please, its for site tracking only:
<script>
  (function(i,s,o,g,r,a,m){i['GoogleAnalyticsObject']=r;i[r]=i[r]||function(){
  (i[r].q=i[r].q||[]).push(arguments)},i[r].l=1*new Date();a=s.createElement(o),
  m=s.getElementsByTagName(o)[0];a.async=1;a.src=g;m.parentNode.insertBefore(a,m)
  })(window,document,'script','//www.google-analytics.com/analytics.js','ga');
  ga('create', 'UA-71077291-1', 'auto');
  ga('send', 'pageview');
</script>
Picture below:
The blue connector is an Instrument Cluster Plug Adapter 1J0972977 1J0 972 977 For VW Passat CC Audi. It comes with just 16 short leads so I had to swap some of them to match our needs. The little print I made myself for easy connection and extending the cables with a 34p Flat Cable. I only soldered the 17 wires used on Leon Bataille`s Polo Shield out of the 34 wires available on the Polo Instrument Cluster. They go to little screw terminals for easy connection.
