Retarder Handle Part 2
A project log for Real Scania Truck Home Simulator
The Scrapyard and Arduino make a great combination!
jeroen-van-der-veldenJeroen van der Velden 12/11/2015 at 13:260 Comments
Still working on the Retarder Lever, this code is driving me crazy!!!
I made slide 1 below to clear things up for you a bit. My Retarder handle is basically one big Potentiometer (5V, GND and A0). To Simulate this lever with Arduino, I made a breadboard with 6 Potentiometers (slide 2) on it. The pot`s are set to my levers resistance values *** to test my code. Although my lever has only 5 positions (1-5), there is also position 0 so I need 6 potentiometers on my breadboard.
Values***
With 5v connected to PIN 2 and 6 (PIN 2 +) (PIN 6 -):
Pos 0 = 0.53v
Pos 1 = 1.30v
Pos 2 = 2.12v
Pos 3 = 2.94v
Pos 4 = 3.69v
Pos 5 = 4.37v
Without 5v connected to PIN 2 and 6 (Resistance measured between PIN 7 and 2)
Pos 0 = no reading or infinite 4k+
Pos 1 = 1207 ohm
Pos 2 = 582 ohm
Pos 3 = 300 ohm
Pos 4 = 156 ohm
Pos 5 = 052 ohm
So far my code looks like:
byte handlePos;
int val = analogRead(0);
if(val < 100) handlePos = 0;
if(val < 187) handlePos = 1;
if(val < 350) handlePos = 2;
if(val < 518) handlePos = 3;
if(val < 679) handlePos = 4;
if(val < 861) handlePos = 5;
VAL (handle value) explained:
To determine val:
val = volts x 1023 / 5 = :
So:
Pos 0 = 0.53v * 1023 / 5 = 108 val
Pos 1 = 1.30v * 1023 / 5 = 266 val
Pos 2 = 2.12v * 1023 / 5 = 433 val
Pos 3 = 2.94v * 1023 / 5 = 602 val
Pos 4 = 3.69v * 1023 / 5 = 755 val
Pos 5 = 4.37v * 1023 / 5 = 967 val
So:
Pos 0 = 108
187
Pos 1 = 266
350
Pos 2 = 433
518
Pos 3 = 602
679
Pos 4 = 755
861
Pos 5 = 967
Take averages (not sure if needed by now):
Pos 0 no val (infinite ohms or zero, needs further investigation)
Pos 1 (266 - 108) / 2 + 108 = 187
Pos 2 (433 - 266) / 2 + 266 = 350
Pos 3 (602 - 443) / 2 + 443 = 518
Pos 4 (755 - 602) / 2 + 602 = 679
Pos 5 (967 - 755) / 2 + 755 = 861
Now the handlePos`s are stored (byte) in the Arduino, I need to find code to:
When the lever goes DOWN one position, I need one HID keyboardPrint("+");
When the lever goes DOWN two positions, I need two HID keyboardPrint("+");`s
When the lever goes DOWN three positions, I need three HID keyboardPrint("+");`s
When the lever goes DOWN four positions, I need four HID keyboardPrint("+");`s
When the lever goes DOWN five positions, I need five HID keyboardPrint("+");`s
When the lever goes UP one position, I need one HID keyboardPrint("-")
When the lever goes UP two positions, I need two HID keyboardPrint("-");`s
When the lever goes UP three positions, I need three HID keyboardPrint("-");`s
When the lever goes UP four positions, I need four HID keyboardPrint("-");`s
When the lever goes UP five positions, I need five HID keyboardPrint("-");`s
When the lever is in position 3, and I move the lever to position five, I need two HID keyboardPrint("+");
Slide 1
Slide 2
More details in Retarder Handle Part 3!
