Steering first run!
A project log for Real Scania Truck Home Simulator
The Scrapyard and Arduino make a great combination!
jeroen-van-der-veldenJeroen van der Velden 03/14/2016 at 19:530 Comments
Here is a short video of the very first ETS2 Run with the Simulator!
I know, lots of work to be done here. We need to align the steering wheel, fix the steering shaft so it produces less noise etc. Keep watching!
Picture below:
A flexible shaft is connected to the Logitech Driving Force GT Pro. THe bracket made in white is used to hold the steering axle in possition while making less noise than iron-to-iron. We might try some bearings later but they are hard to get and need to be alligned perfect in order to work.
Picture below:
A Toolbox u-joint was fixed on a metal bar to the Logitech Racing Wheel.
The flexible shaft was made from an old screwdriver with flexible shaft.
