You might remember my musings with the XOR gate with interlocked NPN transistors discussed at Bipolar XOR gate with only 2 transistors
But thinking about how XOR is done with pass transistors in CMOS and the structure often creates a MUX, I wondered if I could translate this concept back to bipolar world.
This first result is pretty nice and compact though the circuit is highly unbalanced...
- A is a typical high-impedance input where a high signal is a valid 1.
- /B is a negated low-impedance input that must be shorted to -V to make a valid 1. Another transistor can do the trick though that would create another delay...
- Sel has to swing High and Low...
But for discrete, parts-constrained circuits, that might work...
The output could be used to directly drive another MUX stage if the next MUX swaps the NPN for PNP (and reverse polarity) though a big MUX could also be built with the single-transistor NPN-ANDN gate to then drive a big CTL AND gate.
Has anyone seen this circuit before ?
The MUX seems to work well on this Falstad simulation:
Another Falstad sim was required to validate the enhancements : an additional transistor to de-invert /B can be useful...
The source code is :
$ 1 0.000005 10.20027730826997 50 5 43 w 144 112 352 112 3 v 144 400 144 112 0 0 40 3 0 0 0.5 r 352 112 352 176 0 1000 t 304 240 336 240 0 1 0.6163510467707772 0.6473024119705006 100 t 416 240 384 240 0 1 -0.030951365199723496 0.027087887962126838 100 t 352 304 384 304 0 1 0.6173128261844162 0.6352410780104729 100 r 432 112 432 176 0 1000 r 240 304 304 304 0 1000 r 240 240 304 240 0 1000 w 352 176 352 208 2 w 336 224 336 208 0 w 336 208 352 208 0 w 352 208 384 208 0 w 384 208 384 224 0 w 144 400 336 400 0 w 384 400 384 320 0 w 384 288 384 256 0 w 304 304 352 304 0 L 240 304 208 304 0 1 false 3 0 L 240 240 208 240 0 1 false 3 0 L 240 368 208 368 0 1 false 3 0 w 336 400 384 400 0 w 336 352 336 256 0 w 336 352 432 352 0 w 416 240 432 240 0 w 432 240 432 352 0 t 304 368 336 368 0 1 0.6161066110712008 0.6611227508593843 100 w 352 112 432 112 0 w 432 240 432 176 0 w 336 400 336 384 0 w 464 208 384 208 0 r 240 368 304 368 0 1000 t 464 208 496 208 0 1 -2.924032495012093 0.07596750308398237 100 w 432 112 496 112 0 w 496 112 496 192 0 r 496 288 496 400 0 1000 w 384 400 496 400 0 w 496 224 496 288 3 38 18 2 0 3 B\sLow 38 18 1 0 3 B\sHigh 38 19 2 0 3 A\sLow 38 19 1 0 3 A\sHigh 38 20 2 0 3 CLK\slow 38 20 1 0 3 CLK\shigh
I have re-wired the B base resistor : it's now a pull-up that is shorted to 0V by the main SEL input. I added another transistor on the B input to get rid of the inversion (and some isolation).
The output is inverted with an common collector output stage, though an open collector is also possible, it would re-invert the value and make it a non-inverting MUX.
The select input and transistor can be shared by more than one MUX, which makes it an attractive solution for selecting a whole bus for example.
Here is the non-inverting MUX with open collector output :
So this is the version that would solve the problem found by @roelh :-D
And when you have a MUX2, you can cascade 3 of them to build a MUX4 :-)
There are inversions here and there but some are opportunities to save a transistor.
Nice MUX gate, Yann ! Could also be used for DCTL when base resistors are removed.
but that could fry the base if it is not protected...
In DCTL, the base current is limited by the collector resistor of the previous stage, so the base resistor can be omitted. You just have to be careful when a stage drives several inputs.
I overlooked that detail, yes :-)
